ni_security_salapi.dll
Thanks! I had the same issue, solved with mass compile of the vi.lib\lvdsc directory.
Message 11 of 19
(1,735 Views)
Thanks for letting us know.  It is good to hear when it may be a wider problem than just my particular system setup, and good to have confirmation that a particular action helped fix it for you.
Message 12 of 19
(1,724 Views)
Update on this issue.
I just upgraded my work PC (XP SP3) from LV 2010 to LV 2010SP1.  I had a problem with this PC also when the dialog window opened when I needed to edit the items of an enum.  It spent a long time searching for ni_security_salapi.dll.  I'd say a good 30-45 seconds.
I tried mass compiling C:\Program Files\National Instruments\LabVIEW 2010\vi.lib\Platform\security.  No luck.
Then I tried mass compiling C:\Program Files\National Instruments\LabVIEW 2010\vi.lib\lvdsc.  That did the trick.  The mass compile process took nearly 5 minutes and left me with the attached error log.
Take particular note of the last view lines that specifically mention ni_security_sapi.dll.
Message 13 of 19
(1,684 Views)
I have also faced this issue and haivng the DSC module installed on my machine with LV 2010 SP1 and  the above solution worked for me as well...thanks for it
Message 14 of 19
(1,566 Views)
I am facing the same issue now. Thank you all for the udpates.
I will try mass compile and see if it solves my issue. Its really frustrating to stop your work and wait for the dll to be loaded.
Regards
Freelance_LV
TestAutomation Consultant
Message 15 of 19
(1,530 Views)
I had this problem also. Mass Compile of the lvdsc folder as mentioned above solved the problem.
LabVIEW 2010 SP1 (32 bit) on Win7 (64 bit).
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
Message 16 of 19
(1,516 Views)
Yes!!
Its fixed! finally!
Thank you all
Regards
Freelance_LV
Message 17 of 19
(1,506 Views)
I am a little surprised that no one from NI had commented into this thread with a confirmation that this was a bug and providing a CAR#.
For the record, it looks like this was identified as a bug and assigned CAR #292948.  And according to this link, LabVIEW 2011 Bug Fixes, it was fixed in LabVIEW 2011.
Message 18 of 19
(1,498 Views)
This works.  Thanks for the direction!
I found it still took a while to load ni_security_salapi.dll as it searched through the directory.  I make a copy of this file and moved it to C:\Program Files (x86)\National Instruments\LabVIEW 2010\resource\PropertyPages\Pages.
Properties menu opened up much faster.
Thanks again!
Andrew
Message 19 of 19
(1,348 Views)
