ni switch controlling relay
Hello lvuser333
Since these steps are not working for you, I recommend you to install again the driver and the support files. I have the NI SWITCH 4.6.1 and I could find that example there. So, if installing the same version is not solving the issue, you could try installing a newer version, but the example should be there. As moderator showed you before, you need to be sure that you are installing the support files for the LabVIEW version you have. So I recommend you to focus on that installation.
NI Switch
Regards
Frank R.
Message 11 of 11
(264 Views)
