ni vision assistant calibration
Hello to all.
I'm using Labview NI Vision Assistant to calibrate a square image (1024x1024) of a circular grid.
I use the command "Image Calibration" and I choose "Distortion Model" as the calibration type.
I do the steps, when I arrive at the "Step 6: Specify Axis Calibration" change the image size, but still the output calibrated image has size of 1024x1024.
Then I use the "Image Correction" command but the output image has different size from the original.
Can anyone tell me how can I solve this problem please?
I'd be grateful!
thank you!
(5,432 Views)
Can you post your calibration grid so I can try the same steps?
Matt Fitzsimons
NI Alliance Member
LabVIEW Champion
NI Certified LabVIEW Architect
LabVIEW, LV-RT, Vision, DAQ, Motion, and FPGA
(5,423 Views)
Yes,sure. The distance between the dots is 22.5 mm.
(5,393 Views)
I used Vision Assistant 2015 and got calibration sucessful following your steps. Not sure what is the issue.  Try to load the attached NIdotcalibration image and see what happens.
Matt Fitzsimons
NI Alliance Member
LabVIEW Champion
(5,336 Views)
Hi, thank yuo! Can you send me the NI Vision Assistant file please?
Antonella
(5,315 Views)
The NIdotCalibration.png image is the output of the calibration process.
Matt Fitzsimons
NI Alliance Member
LabVIEW Champion
(5,307 Views)
ok, but I see that your output image and the original image are the same, it seems that your image is not calibrated. Sorry!
(5,229 Views)
