niScope Configure Trigger Edge sending error to niScope Initiate Acquisition
I'm getting an error from my Trigger off of my scope that keeps failing the program. The error code is -1074135022,
it says
niScope Initiate Acquisition.vi:1<ERR>Attribute or property not supported.
Device: NI_Scope
Property: Trigger Holdoff
Status Code: -200197
I'm using an NI-5133, running Labview 2011 and scope 3.9.4
Thank you for you help!
Wolley
(4,513 Views)
Wolley,
Try eliminating the 5E-7 from the trigger holdoff input on the Configure Trigger Edge VI.
James K.
(4,488 Views)
Upon doing so, I now have an error that I think is due to it trying to trigger while collection is still taking place. I may very well be wrong in this, though. It comes out of the niScope MultiRead block, and says
niScope Multi Read WDT.vi:1<ERR>A previous acquisition is still in progress. If you are attempting to change an attribute, note you can only change fetch attributes while an acquisition is still in progress.
Status Code: -1074118647
Attached is the current state of the VI. I don't think the minor changes I've added in should be causing the error.
Wolley
(4,483 Views)
Wholley,
I would recommend taking a look at the example niScope EX Configured Acquisition.vi (Example Finder->Hardware Input and Output->Modular Instruments->NI-SCOPE->Demos) to have a starting point for something that works with a trigger.  Also, I would recommend modifiying your code such that you are not creating/closing the hardware reference with each iteration of the loop.
James K.
(4,473 Views)
I've made some moderately substantial revision, and have attached my current VI. Triggering seems fine now, but I now can't get any measurements because of an error code -1074126847.
It says
niScope Fetch Array Measurement.vi:1<ERR>Specified channel is not enabled.
Cannot fetch waveform from disabled channel.
I've verified that my scope is working fine through the soft front panel, and is able to measure off of channel 0 as I'm trying to do. I don't know why it would refer to that channel as being disabled. Any thoughts?
Wolley
(4,458 Views)
Wolley,
Try adding a niScope Configure Chan Characteristics VI after the initialize VI.
James K.
(4,448 Views)
