nicaiu.dll installation
Hey everybody!
First time posting, as I'm pretty new to NI tools in general.
Background:
I am using Python to control niDAQ's. I do this by calling nicaui.dll methods in C, and then I wrap that in python. Since I had been using Labview previously, I have the drivers installed for my setup, as well as it's dependencies. However, I want to put the python script on another computer along with a small installer for only the bare-bones of DAQ operation. I have been going through the driver installation CD and trying each .msi to try and sniff out the smallest amount of installing I need to do in order for me to get a callable nicaiu.dll. This process is somewhat tedious and building an installer from LabVIEW was equally bloated. So, given this information...
What is the bare minimum installation (.msi or .msi(s)) I can install for nicaiu.dll to support analog voltage output for all of the following pieces of hardware:
PCI 6024E, USB6353, USB-6259 (I know there are more devices supported by nicaiu.dll...but these are the three I have)
Thanks for your help!
DL
(6,732 Views)
The minimum driver is the DAQmx core version and you can download the version you want. The installer in LabVIEW supports this as well.
(6,726 Views)
This solved my problem but the installer is still quite bloated. Thanks for your help!
(6,675 Views)
