nican.dll required when exe is run
I have an CAN based application developed in Labview where i use CAN API's.
I build the application with the installer and try to run the executable of the application in different machine where there were no NI software or hardware is present (as a standalone),the application searches for nican.dll during loading.
From where i can get this, is it that it needs to be included before i build the application somewhere or whats the solution?
The version of CAN driver used 2.3.
-Murali
(2,808 Views)
You need to include the NI-CAN driver when you create the installer. Select additional installers. You should have this on your hardward driver DVD or you can download it.
(2,787 Views)
