nidevmon crashes in labview 2010
I have just installed labview 2010 on a new windows 7 machine. When I install the niDAQ software, automation explorer does not recognize my DAQ board (pcie-6259).  Windows says the board is fine, and recognizes it,
The problem appears to be with a program called NIdevmon which crashes on startup.
Have disabled all antivirus software and firewall.
Have reinstalled labview several times.
Any advice would be gratefully appreciated.
(2,647 Views)
Hi simwat,
nidevmon is a helper app that displays a dialog when you plug in a USB device. nidevmon is not necessary to operate your PCIe-6259. That said, it shouldn't crash, and the fact that it does crash may reveal more clues as to why your device doesn't work.
How does nidevmon crash? Can you post a screenshot?
Are there any errors from NI software (e.g. NIPALK or NIDEVLD) in the Windows Event Log?
Are there any crash dumps in C:\ProgramData\National Instruments\MAX\Logs?
What version of NI-DAQmx did you install?
What antivirus/firewall software did you disable?
Brad
Brad Keryan
NI R&D
(2,639 Views)
Hi Brad:
Here is the screen dump
Problem signature:
  Problem Event Name:                        APPCRASH
  Application Name:                             nidevmon.exe
  Application Version:                           1.8.0.49153
  Application Timestamp:                     4bcdb838
  Fault Module Name:                          nimxdfu.dll
  Fault Module Version:                        1.11.5.49153
  Fault Module Timestamp:                  4c1f8f98
  Exception Code:                                  c0000005
  Exception Offset:                                0000430c
  OS Version:                                          6.1.7600.2.0.0.256.48
  Locale ID:                                             4105
  Additional Information 1:                  4c0d
  Additional Information 2:                  4c0d4d78887f76d971d5d00f1f20a433
  Additional Information 3:                  4c0d
  Additional Information 4:                  4c0d4d78887f76d971d5d00f1f20a433
I could not find the NI log file you spoke of. (Is that the correct location for windows 7?)
I am using NI-DAQmx 9.1.5
I disabled windows firewall
I unistalled Macaphee anitvirus temporarily.
Simon
(2,615 Views)
Problem resolved:
I reinstalled windows 7 and reinstalled labview 2010 and now it sees the PCIe device.
Must have messed up some registry files with all these install/unistalls.
(2,597 Views)
Hi Simon,
Glad to hear you were able to work around the problem. If it starts crashing again, please post here or contact NI technical support.
In regard to the log file location: yes, that is the correct location on Windows Vista and Windows 7, but not XP. Also, C:\ProgramData is a hidden folder, so it won't show up in Explorer by default.
Brad
Brad Keryan
NI R&D
(2,578 Views)
