nidll.tlc does not generate .dll file
Hello all,
I have been following the tutorial at http://zone.ni.com/reference/en-XX/help/371504F-01/lvsithowto/sit_h_convert_model_to_dll/
After I click "Build", MatLab says: Successful completion of Real-Time Workshop build procedure for model: sinewave.
Except when I go into the Sine Wave\sinewave_nidell_rtw folder, there is no .dll file! Where is a dll file?
This is what my setting is in Simulink, and I click on that "Build" button to build:
Thanks.
(2,659 Views)
Would you mind posting the contents of the modelsources.txt file?
(2,611 Views)
I finally found it in C:\Simulation Interface Toolkit\
Thanks.
(2,599 Views)
