niimaqk
hi all,
I am having a problem when running MAX that it cannot find all databases. while trying to solve this problem I found that both niimaqk and PartMgr drivers (Device manager> view> show hidden devices) are no working properly. Could be it be the reason that MAX is not working? Should I reinstall the drivers? Where I can find these drives ?
regards
(3,070 Views)
As first step try to repair the drivers and MAX.
Christian
(3,059 Views)
hi,
I tried to repair it did not work. I had an error. I tried to install it yet there are so many dependents and i have to install them all and I am not sure if i did so I will solve the problem
(3,041 Views)
mssm22 wrote:
hi all,
regards
I never did the "Device manager> view> show hidden devices" trick but did it now and guess what?!?
PartMgr also shows an error and I don't have niimaqk at all Smiley Surprised
Nevertheless, MAX 4.5.0f0 is working fine on my system Smiley Very Happy
If the MAX is the problem I would uninstall and re-install it and don't bother about those drivers.
(3,036 Views)
