nimax.exe - Application Error. Instruction at 0x6d8e3e61 referenced memory at 0x00000000. The memory could not be "read."
On startup I get a nimax.exe application error.
The instruction at "0x1ce30df7" referenced memory at "0x00000000". The memory could not be "read".
This happens every time I start the computer, run a vi with the initialize.vi or try to use the measurement and automation explorer.
I am running windows XP, Labview 7.1,  and max 3.1.1
(3,135 Views)
I had a similar problem in win2000 / max 3.1.1.  I do not recall the exact memory location error.
It happened every time I started the computer, or once started, evrytime I load a vi that has some daqmx functionlity.
I reinstalled windows / Nidaq, and never had the error again.
(3,127 Views)
