nimax.exe application error
I am getting the following error message when trying to run LabView:
The instrucion at "0x6465290c" referenced memory at "0x00000000".  the memroy could not be "read".
The program was running correctly yesterday.
(3,042 Views)
Are you getting this error when you launch LabVIEW or when you run a program?  What version of LabVIEW are you using?  Does this occur on a single machine?  Have you restarted LabVIEW?  Have you restarted your computer?  Have you reinstalled LabVIEW?
The following document addresses those issues; give it a read and perhaps it'll help you in your particular case:
Title: LabVIEW Application Error: The instruction at "[address x]" referenced memory at "[address y]". The memory could not be "read"
Link: [link removed; article no longer available]
The more information you can provide, the better!
Looking forward to your next post!
Best Regards,
JLS
Best,
JLS
Sixclear
(3,028 Views)
