02-14-2008 02:32 PM
08-31-2012 01:27 AM
This is an old post!
¿But someone has the solution?
I have same problem in XP, LV2011.
04:39 PM
- last edited on
01-23-2026
11:59 AM
by
Content Cleaner
Hi Edupo,
While NI DAQ 6.9.3 is compatible with Windows XP, it is not compatible with LabVIEW 2011. This link illustrates all of our DAQ and DAQmx drivers and their compatibility with past versions of LabVIEW. I would recommend upgrading your older VI to support the DAQmx drivers. Here is a good article that explain how to do this. The correlation is not exact between traditional DAQ and DAQmx, but I would certainly recommend performing the upgrade.
Warm Regards,
09-02-2012 06:37 AM
Thanks tannerite for the answer.
I not described my problem very well.
I'm developing in LV2011, W7 and DAQmx 9.5.5 for computers with XP and without LV. When I make the Installer I'm not including DAQmx and because of that I have an error with this file. Now I've solved the problem with this information.
Regards.
01-17-2013 06:41 AM
I'm developing in LV2011, W7 and DAQmx 9.5.5 for computers with XP and without LV, like you... How do you do to ? Please I need your help
01-17-2013 09:54 AM
In my case I make an installer selecting on the "Adittional Installers" menu the "NI-DAQmx Core Runtime 9.5" This install the library and make my app to work.
You only need to make the installer once and then you can only copy your app *.exe
Hope it helps to you.
02-22-2014 09:19 PM
Hi to everyone!
I've just wanted to launch NI Update Service 2.3 because I noticed that for a while it didn't appeared so I launched it and a warning appeared telling me that NIPALU.dll wasn't found in the system.
I tried to repair it going to Programs and Characteristics/Software National Instruments -> and choosing the program you want (in this case the updater) but when a submenu from NI appeared displaying me three options, I chose the Repair tool but it didn't work. So I investigated...
I read in other forum (http://lavag.org/topic/17917-avast-deleted-nipaludll/) that a possible cause for this mistake may be the new version of Avast! Antivirus' trunk. And, for my case that was the problem: The new version of Avast had retained in, the file NIPALU.dll thinking it may be a virus.
Then, you just select the file and make it a "Global exception" for avast! to always ignore it and stop thinking it's a harmful file (before you perform all of this make sure you have NI Update Service closed). Then, you just open it again and you're done!
10-25-2014 06:45 PM
I had the same problem (nipalu.dll) updating NI SCOPE. I solved my problem by simply restoring the sytem.
