niscope Initialize error - Windows Server 2008 x64
   I'm trying to use Labview with Windows Server 2008 x64, since I hear its the same codebase as Vista and you support Vista x64.  I'm receiving the following niScope Initialize error though when I try to run a vi.    Does anyone know what it might mean?
niScope Initialization error
-Sidney
NI Hardware: PXI-7853R, PCI-5122, PCI-6733, PXI-1036, PCI-MIO-16E-4, PCI-6110
Computer Hardware: Xeon Quad Core - 2.33 Ghz, 8 GB RAM
Software: Labview 2009, Labview FPGA 2009, Vista 64-bit, MAX 4.6, DAQmx 9.0, NI-SCOPE 3.5
(3,040 Views)
Due to the fact we actually not support Windows Server 2008 I would suggest to test the card with anohter OS system if possible.
If you have the same problem there I would suggest to call your local NI Office to figure out if it might be a hardware defect.
Christian
(3,037 Views)
No, everything works fine with Vista, and XP... I just want to move to Server 2008 to try our their Terminal Server capabilities..
ok, thanks I guess
-SIdney
(3,034 Views)
