nismECATAdapter.dll Not Found Error - cRIO 9082 RT
I am deploying to a cRIO 9082 Realtime system. During the startup, the console outputs the above error, but I can't find anything referencing this dll online. It's like it doesn't exist. My best guess is that it's an NI EtherCAT Adapter? Here is the complete startup Console output:
Datalight Reliance v2.10.1053
Copyright (c) 2003-2006 Datalight, Inc.
LabVIEW Real-Time Executive
Build Time: Jun 5 2014 14:22:59
(C) Copyright 2002-2014 National Instruments Corporation
MAX system identification name: Chassis1
LabVIEW Real-Time SMP Kernel: CPU cores found: 2
Initializing network...
Dev|Op M|Link|Driver|MAC Address |IP Address /Mask|Adapter Mode
* 1|Int |U |i1000e|00802F17EE7A|10.0.1.241 /24|TCP/IP (static)
2|Int |- |nigev |00802F17EE7B|- -|Disabled
Time sync source: ptp now active
Device 00802F17EE7A is now connected
System Web Server started
Application Web Server started
Error! nismECATAdapter.dll not found! (dependency)
SoftMotion Module initialized.
NI Scan Engine initialized.
NI-RIO Server 14.0.1 started successfully.
Startup Application: c:\ni-rt\startup\startup.rtexe
NI-VISA Server 14.0 started successfully.
Welcome to LabVIEW Real-Time 14.0
Hopefully someone out there has seen this dll before?
Cheers
(3,884 Views)
Accepted by topic author James.M
Looks like you need to install the EtherCAT driver onto the cRIO and/or your system.  Here's a link to EtherCAT driver for Windows: NI-Industrial Communications for EtherCAT 14.0 - Windows
(3,867 Views)
Well I'll be damned. I would have thought one of the 50 searches I did would have come up with that. Partly I guess I wasn't sure exactly what I was looking for.
Thank you! Hopefully this topic will show up if others need to find that library.
Cheers
(3,837 Views)
This is in the SoftMotion known issues list (although the error needs to be updated). You can ignore the error if you aren't using an EtherCAT device.
(3,808 Views)
