nixsrk.dll causing system to sporradically reboot
Hi Ethan,
Combining both of your analog inputs into the same task should clear the error. If you want to learn more about DAQmx tasks and DAQmx channels, there is a good section in the NI-DAQmx Help file which is installed with the driver.
Kent
Message 11 of 11
(545 Views)
