nn
i am using labview 2012 and i m trying to turn on a led at analog output 0 of my 6221 device at a specific time every day for 5 minutes .
what command in timing should i use?
Thank you
(3,496 Views)
Command? LabView? I don't understand. But if you're trying to say VI you might want to start with to know how daqmx works.
https://www.ni.com/en/support/documentation/supplemental/06/getting-started-with-ni-daqmx--main-page...
Kind regards,
- Bjorn -
Have fun using LabVIEW... and if you like my answer, please pay me back in Kudo's 😉
LabVIEW 5.1 - LabVIEW 2012
(3,490 Views)
yea of course i mean VI ,it is perhaps something in the timing palette?
(3,488 Views)
And the vi for timing? If its just on the second that you want to use? Timestamp might be the better option. You can find it on the timing palette
Kind regards,
- Bjorn -
(3,482 Views)
