no Create New option under MAX - Devices and Interfaces
I downloaded LabVIEW  2014 SP1 for evaluation, and need to create simulated devices to follow the tutorials.  When I open MAX and right-click on Devices and Interfaces, there is no Create New option, either in a pop-up menu or in the Devices and Interfaces display.  Expected Create New… » Simulated NI-DAQmx Device or Modular Instrument.  NI DAQmx is installed.  Has anyone encountered this or have a suggestion?  Hope to get this running before the evaluation period is up.
(5,297 Views)
Accepted by topic author cmelfi52
You are trying to find this?
(5,289 Views)
Yes - that is what I was expecting.  I found that NI DAQmx was not properly installed, downloaded the latest and it started working.  Thanks
(5,258 Views)
I just now ran into the same problem.  No Creat New option...
I will try to re-install...
Regards
(5,205 Views)
