no case for some selected values
Hi, I need some help on create VI model.
I need create model shown on Pic. 1.png, but I have problems with case structure, it report "Case Structure: No Case for Some Selector Values".
P. S. Sory for bad English Smiley Indifferent
Message 1 of 12
(5,143 Views)
Hi Orochimarko,
your uploaded picture is not the same as the VIs you also uploaded. Atleast when opening them with LV2011 they differ from the pic...
The case structure in your VI only has one case ("True"), but there is no False-case. So you get the error "no case for some values"...
Btw.  both VIs are crowded with Rube-Goldbergs. Even considering the old LV version they are saved with wouldn't allow for such bad programming behaviours...
@V-F:
What's the sense of making the only case of that case structure a "default" one? What's the sense of that case structure at all???
Message 2 of 12
(5,132 Views)
it's because there is no default value : right click on case structure => make default.
Best Regards,
V-F
Message 3 of 12
(5,130 Views)
When it have true- and folse-cases, it report this error too...
I try create "0, Default" case, as shovn on picture, but it report "selector values has wrong type"
I create this in LabView 7.0
Message 4 of 12
(5,123 Views)
This structure is just labwork...
Message 5 of 12
(5,122 Views)
Hi Oro,
in the picture posted you have connected the slide to the case selector. In the VI posted a boolean wire is connected to the selector input...
Please state (clearly!) what you have connected to the case selector input and which cases you have configured.
Or simply post your current VI again...
Message 6 of 12
(5,105 Views)
Do you mean connect slide to shown in Attachments ?
if yes, than can you explane how to do it? Beacose I try do it early, and can't...
Message 7 of 12
(5,099 Views)
Hi Oro,
you just attached the picture of the case selector. What do you want to tell us with that picture?
To connect the slide with the case selctor you just use a wire in LabVIEW. Try it!
Message 8 of 12
(5,093 Views)
When I try connect slide to case selctor with wire, it don't connecting... I think, I need do something with case selctor before connect it.... But don't know what...
Message 9 of 12
(5,090 Views)
You already have connected a boolean to the Case selector (Click the Diagram cleanup and see). Remove that boolean and try connecting it.
Message 10 of 12
(5,073 Views)
