no connection after building a stand-alone rt application
Hi everyone
I've currently tried to generate a stand-alone application of one of my RT-VI's. I generated it as a start-up program under the cRIO Build Specs. Now I cannot stop the running program on the cRIO nor can I connect to the device.
What can I do?
cheers Smiley Happy
Message 1 of 9
(3,906 Views)
Your RT VI is probably consuming all of the available CPU resource on the cRIO which will make it unresponsive. You will need to either try to restart it from MAX with the no-startup-VI option ticked or restart it in safe mode (either from the physical DIP switches / reset button) or from MAX.
(blog)
Message 2 of 9
(3,899 Views)
thanks a lot
I'll try it soonSmiley Happy
Message 3 of 9
(3,893 Views)
Good morning
All my attempts to connect to the cRIO failed. Just in safe mode a restart in MAX was possible and a reboot of the device didn't change the situation. Now I descided to format the targed system. Hope that this will enable me to connect to the device again.
How can I set up a proper stand-alone VI or an executable program that can be used by any other user to operate the cRIO - to use the Software I created? I was following the instructions of NI advices but I couldn't operate the cRIO from my front panel. It just ended up in a "self-running" program on the targed with no access to it anymore...
thanks a lot
cheers Smiley Happy
Message 4 of 9
(3,862 Views)
Remember at a cRIO program is a free runing program that has no front panel.
A cRIO is a stand-alone computer, that should have its own program.
If you need to talk and control the cRIO you should make a host program that can communicate to the cRIO program.
There are multiple options to make communication between a host program runing on a PC and the cRIO.
What have you done so far?
Message 5 of 9
(3,843 Views)
I've tried to set up a "Invoke Application property RemotePanel:Open Connection To Server" but I get the error message Error 1346: Labview. Server does not support remote panels"... although I searched for solutions in the internet and I've found the following:
https://lavag.org/topic/6351-crio-wremote-panel/
I also tried to set up the Real-Time CompactRIO Properties for the web server, user access VI server etc. but I am not sure what I've to enter as Debug HTTP Port (Web Service Local Debugging), HTTP port (Remote Panel Server)...I enabled the check marks for Remote Panel Server and Remote front panel...
I also entered the VI-Nabe of my running VI in the "Visible VIs"-field but I didn't know what to enter in the "Browser Access"-List...
The VI Server Protocols are disables
User Access: I entered the IP-Adress of the target in the Target Access List
Since I am not experienced at all in this I have to ask "stupid" questions Smiley Wink
thanks a lot
Message 6 of 9
(3,834 Views)
As others have said, you need to implement some sort of communication method between the RT executable running on the cRIO and Windows over the network. The fact that you can 'run' an RT VI and have it's front panel displayed and updating is kind of confusing because once you build it into an RT executable it essentially becomes a 'headless' application with no UI. You need to write a VI that runs on Windows and communicates with the cRIO over the network (e.g. using network shared variables, network streams, TCP/IP etc.).
There are examples built into LabVIEW and there is also the 'cRIO Developer's Guide' available here: http://www.ni.com/pdf/products/us/fullcriodevguide.pdf
You might be able to connect to the RT VI while it's running using remote front panels if it enabled or using 'debug application or shared library' if the VI is configured correctly.
(blog)
Message 7 of 9
(3,827 Views)
Hi Sciu,
please also take a look at the LabVIEW Example Projects.
Developer Walkthrough of the RIO Sample Projects - National Instruments
http://www.ni.com/video/2725/en/
Peter
Message 8 of 9
(3,793 Views)
Hi everyone
thanks for all the suggestions and advices 🙂
have a nice day
Message 9 of 9
(3,774 Views)
