no devices available in realtime mode on Desktop PC
One data acquisition computer of mine has the following cards built into it:
PCI-6229
PXI-6259 (via pxi-1033 chassis)
They are recognized fine and work perfectly booting this computer with Windows XP.
If I boot this very same computer using a "Desktop PC" realtime hard drive, I don't see any of the two devices in MAX. I do see the PXI-1033 chassis but all slots are listed as empty.
I would have assumed that at least the PCI-6229 would show up - but no.
My Desktop PC real time system has all available packages installed.
what can be the problem?
(2,815 Views)
Accepted by topic author kandreas
Hi There,
Good Morning and I hope your well today.
Thanks for the post!
So you are trying to few the Real Time PC under remote systems in MAX from another machine?
What version of DAQmx have you got installed on the remote real-time PC?
Missing NI-DAQmx Devices in Measurement & Automation Explorer (MAX) Under Remote Systems (Real-Time Target)
http://digital.ni.com/public.nsf/allkb/6B06A4E228CF62098625750000614B57?OpenDocument
Deploying DAQmx to Real-Time PC
http://digital.ni.com/public.nsf/allkb/79CB44F7E228AED88625756E00445151?OpenDocument
Hope this starts to help,
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(2,809 Views)
yes. and I do see the system, I can connect to it, I even see a serial port under the device section. But as stated previously, all my DAQ cards are not showing up.
8.7
YES, that was the key!!
thanks.
(2,799 Views)
Hi There,
Thanks for the prompt reply. I am glad you've managed to get it working.
Thanks also for using one of the two newer features of the forum, the selected answer. Have you seen the kudos feature before :smileyhappy:
Kind Regards
James Hillman
(2,796 Views)
