no file created with write to measurement file express vi
I inherited a data acquisition system using a FieldPoint connected to pc running LV 8.2.1.  Application looks at 4 load cells and uses “write to measurement file” express vi to create a .lvm file.  I have wired the outputs from vi to show path and filename created plus a Boolean to verify write occurs.  However, I go to directory and no file is created.   I have tried multiple settings in the express vi including creating single file, multiple files, simple filenames, no files get created. TIA,emseedee
(2,633 Views)
Could we please see your code so we can see if you wired something incorrectly?
Cory K
(2,622 Views)
