no listeners condition is detected
Hi all,
I´ve written a simple program to control the solartron 1287 using the GPIB-USB-HS and basically I am getting this error:
No listeners condition is detected (both NRFD and NDAC are deasserted)
The cable and the address is fine, the thing is that when I highlight the execution to see where the error is produced I get no error and get the answer I want...
Any suggestions please?
Thanks a lot
(5,654 Views)
When you highlight execution it slows down the execution of the code significantly so sometimes errors that might occur because of timing might not occur.
Without seeing any code it's impossible to help you diagnose/fix the issue. Please show us your code so we can help.
(blog)
(5,645 Views)
Here you are
Thanks a lot
(5,636 Views)
@rodriferfe wrote:
Hi all,
Thanks a lot
Did you bother to put probe points to see where the error is first occuring?
(5,627 Views)
Yes, the error is produced after the write OT2 wich sets up a cr for the outputs, either if a remove this write or not the problem is still on, if a remove the next write (OL1) then the error appears in the next write. I also put wait between them to give then some time but it didn´t work
(5,611 Views)
by increasing the wait time between 2 writes it works, probably it was sending commands but it wasn´t still ready to perform them
(5,606 Views)
Exactly
That old bird is not going to chew through commands very fast at all
I would suggest you create a write solartron vi that contains a VISA write and a delay with Error In,  String and Delay inputs and Error out.
You can use that to trap the error source and lengthen the preceding calls delay.  Eventually you will learn which commends need how much time to process before the instrument is ready for the next command
(5,573 Views)
