no output from string subset
Why you guys make me do your homework? Any way some times I enjoy it. find attached snippet.
With Regards
Miraz
Kudos is better option to thank somebody on this forum
Message 11 of 13
(953 Views)
Related thread.  http://forums.ni.com/t5/LabVIEW/urgent-inquiry-how-to-read-value-from-a-register-using-VISA-read/m-p...
Note that the string data there should already be in hex display.
Message 12 of 13
(930 Views)
Hi GerdW,
As per Cantata's info, we know there are how many bytes and which byte need to be indexed.
If taking string subset first, as you pointed,
There's a difference in "normal" and "hex" string display - and so the byte offset and length differs when we want to have a certain subset…
Message 13 of 13
(920 Views)
