(no subject)
is there any way to make a comment block,
i.e. /* comments.... */
in labview?
I suppose you could enclose your code in a case or while loop that never
executes- but what if
you are trying to comment out code that doesn't work?
Seems like this would be handy when you are debugging, and have the luxury
of commenting out
part of your program you don't need to work on-
or during documentation when you need to write some example code that you
don't want to interfere with anything else.
(2,677 Views)
see other reply to this same question..
Certified LabVIEW Architect
LabVIEW Champion
(2,677 Views)
