no supported physical channels
I am new to using Labview and installed the student edition. i am going through the getting started with labview but can not complete chapter four due to NI-DAQMX not working. If you see the attachment you will see why and was wondering if somebody can tell me what i have to do to fix this problem. Under devices and interfaces there are no devices listed and under supported physical channels there are none.
John
Message 1 of 10
(4,511 Views)
The student edition does not include the DAQmx driver. It is something you need to download from the Support page. Did you do that?
In the future, don't attach proprietary files. Much simpler to directly attach the png or jpg file.
Message 2 of 10
(4,505 Views)
Yes i did down load that driver. Do you think i need to down load the NI-Devices Driver.
John
Message 3 of 10
(4,494 Views)
There is no such thing. What is your DAQ device?
Message 4 of 10
(4,492 Views)
DAQmx
Message 5 of 10
(4,489 Views)
That is the software driver. What is your physical device?
Message 6 of 10
(4,484 Views)
Agilent E363x series output DC volts. I think this is what you mean by device?
Message 7 of 10
(4,471 Views)
That is not an NI DAQ device and trying to use the DAQ Assistant is just silly.
Use Help> Find Instrument Drivers if you intend to control it. It would have nothing to do with a DAQmx tutorial, though.
Message 8 of 10
(4,468 Views)
See here about downloading drivers for the Agilent E363X.
http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=0475216F9FCA5335E0440003BA7CCD...
Message 9 of 10
(4,418 Views)
Thank you all for the info.
Message 10 of 10
(4,407 Views)
