node property global variable
How could i access to the property nodes of a global variable ?
Thx,
Samer,
Message 1 of 17
(6,436 Views)
You would need to open a reference to the VI and then access the front panel and then the controls on the front panel. For example, this will return the labels of all the controls on a global variable:
Message Edited by smercurio_fc on 07-15-2008 11:46 AM
Message 2 of 17
(6,429 Views)
Hi samer,
even with smercurios excellent answer:
Why do you need to access property nodes of global variables??? What do you want to achieve?
Message 3 of 17
(6,403 Views)
Gerd pondered
I am curious as well. We may be able to offer alternatives.
Ben
Message Edited by Ben on 07-15-2008 03:03 PM
Message 4 of 17
(6,390 Views)
Sometimes I just throw my hands in the air and don't bother asking this and just decide to answer the question as stated, since I know the poster will likely follow up with the real question, or additional information that completely changes the premise of the question.
I suspected it had something to with this.
Message 5 of 17
(6,380 Views)
Hi GerdW & ben...Thank you for your concern...Smiley Wink
smercurio_fc is right...Smiley Happy i was asking the question in relation with this subject: http://forums.ni.com/ni/board/message?board.id=170&message.id=339923#M339923
In the subVIs and the VI i need to access to the property nodes of the global variable...
What do you think ?
Samer,
Message 6 of 17
(6,363 Views)
Hi samer,
you still don't say why you need to access properties of global variables...
Globals should only be used as data storage/provider. You don't show the fornt panel of a global vi to the user, so properties are irrelevant...
Message 7 of 17
(6,361 Views)
Uhm why not, I have done it  in the past as an advanced debug function.
Ton
My LabVIEW Ideas
Message 8 of 17
(6,340 Views)
Hi Ton,
that's an interesting point! (Always trying to improve my LV knowledgeSmiley Wink)
Did you use properties to show different states of the running vi?
Message 9 of 17
(6,330 Views)
sorry for answering late...
The reason of needing the global variable node property is that i have a listbox variable in my global variable vi ...and I need to access to the properties of the listbox in my vi and subvi.
in my subvi I need to read to the contents of  this listbox...and in my vi i need to wrtite into the listbox...so i need the properties to do so....
Is smercurio solution is what i need ?
if not could you help me ?
Samer,
Message 10 of 17
(6,244 Views)
