noise and baseline of a signal
Hi everybody,
I would like to determine baseline of a signal. I attached a signal figure as an example. How can I determine the noise value in figure or calculate the baseline?
Thanks.
(3,082 Views)
Do you know any Signal Analysis?  Do you know how "baseline" and "noise" are commonly defined?  This is not a LabVIEW question, but a question about understanding Signals and what to do with a time-varying waveform.  Once you know that, the relevant LabVIEW code is extremely simple.
Bob Schor
(3,027 Views)
