I am sure your signal is full of inter-harmonics, but again the THD VI will not find these automatically. I see 3 options you could try, (the first one being a little "dirty").
1 - If your inter-harmonics are multiple of a common frequency (like n* 10 Hz), you may be able to use the THD VI with some modifications. Make your fundamental search around 10 Hz, (assuming there is a tone there, even though it may be small). Then the THD VI will return a THD value that is useless (since it considers your 60 Hz tone as a harmonic), but the VI also returns an array of RMS values (DC, 10 Hz, 20 Hz ...). You can then extract the components you are interested in (like everything but DC and 60 Hz) and compute your measurement value. This is, as mentioned, a
dirty trick but it might work for you (no guarranties though!)
2 - You can save the THD VI in another name and location and edit the diagram to your specifications. You can see on the diagram, that the FFT is only computed once, and that the spectrum is passed to a sub-vi called "Extract single tone Information from Hann Spectrum.vi". The VI is used to compute the fundamental and then in the For loop to compute the different harmonics. You can modify the harmonic list to fit your requirements.
3 - last but not least, the SINAD VI could be worth trying. This VI will return the ratio between the signal minus fundamental and the signal. The measurement will therefore include all your inter-harmonics, but also all noise. So depending on your uncorrelated noise level, the result may or may not accurate enough for your application.
