non-matching Strictly Typed VI References
Again I'm banging my head against a brick wall trying to get something done.
I have a set of classes which fire up an asynchronous process but I want to move the launching of the process into the parent class.  To do this I thought of passing back a reference to the asyncrhonous part of the VI to the parent and then calling via Asynchronous node.
I have three different classes with EXACTLY the same controls wired up to exactly the same position on the connector pane but two of them have the same strictly typed reference whereas the third is different.
I see NO reason why the two types of different strictly typed references should exist.  Is there something else that the type of the strict reference is dependent on?
Even highlighting the wire for the different VI refnum wires in the context help window offers no clue as to WHY there are two different strict reference types.  The list of attached controls seems identical.  I've even copied across the controls fromt eh "working" VIs to the the other but to no avail.
Shane.
(3,247 Views)
Check the strict type definition for the subVI refnums by right clicking on the control refnums within the subVI.  If you remove the strict type, could this solve your issue?
(3,228 Views)
Personally, I need some visual aids to understand your problem. I'm assuming you're using static refs to the subVIs, but it's possible you're using cached types, so it would be useful to see exactly what you're talking about.
___________________
Try to take over the world!
(3,215 Views)
I found the problem.  One VI input had a single input configured as "Recommended" whereas the others were all defined as "Required".  I found this by then trying to cast them back anbd forth.  D'oh.
Replacing controls does not change this setting.  My bad, sorry.
Shane.
PS. I dunno, is it possible to have better visibility of the actual "Vi Interface Type" definition?  The context help does not show this information for the strict typed wire.
(3,210 Views)
Sounds like this thread.  There's an example there of using a scripting property to compare the VI connector panes, maybe that helps?
(3,191 Views)
Yup, indeed the very same problem.
(3,178 Views)
