01-20-2011 11:15 AM
That's almost correct. Put ActiveChans and AI.ADCTimingMode in the same property node (drag the bottom to select two properties) and wire it into your task, and I think it should work. ActiveChans has to be first because it applies to all of the properties below it in the same node.
Brad
01-20-2011 11:32 AM
Thank you very much Brad.
Thanks to your step-by-step instruction, now the VI works with 2 analog input synchronised.
05-03-2011 09:16 PM
Thank you very much for your enlightening question!
05-03-2011 09:18 PM
I simulate two devices (cDAQ9174+9206) and run Acq Voltage-Clk Select.vi. It does work.
