normal probability plot
Hello!
I want to build a normal probability plot. There is some block to build this plot or someone has built the code to create this plot?
The purpose of this plot is to graphically assess whether the data in a vector come from a normal distribution. If the data are normal the plot will be linear. Other distribution types will introduce curvature in the plot.
Thanks in adavance!
Bye!
(4,379 Views)
I have the same need.  Has anyone come up with this?
Mark
(4,184 Views)
if i correctly understood you are looking for histogramme.
if so, have a look on  probability density.vi in examples
Regards
Tinnitus
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
(4,171 Views)
Tinnitus,
Close but not quite.  The resultant plot should be a strait line if the data are gaussian.
www.itl.nist.gov/div898/handbook/eda/section3/normprpl.htm
(4,157 Views)
