not able to type into string control
I have a couple string controls on my front panel. I can not type text into the controls when the application is running.
I have looked at all of the front panel settings as well as the string control settings.
I've never had this happen before.
Does any one have any suggestions?
Message 1 of 9
(4,119 Views)
Yes!
Check to make sure the control is not disabled!
pop-up>>>Advanced>>>Enabled States >>>Enabled
I believe it was Dennis that helped me out that day.
Ben
Ben Rayner
Certified LabVIEW Developer
www.DSAutomation.com
Message 2 of 9
(4,119 Views)
It is enabled. Thanks for the suggestion though.
Message 3 of 9
(4,119 Views)
Right click on the control and make sure the third line is "Change to
Indicator." Is the control included in the connector of the vi? If it is,
at run time you would not be able to change the value.
"sdzg'lkmarekngroe" wrote in message
news:50650000000800000094C60000-1079301409000@exchange.ni.com...
> control settings.
Message 4 of 9
(4,119 Views)
Post a sample VI with the controls that you cut and paste from your app.
The other though that comes to mind is that they may be locked.
Just guessing,
Ben
Message 5 of 9
(4,119 Views)
Make sure that there is no front panel decoration in front of you string controls.
Message 6 of 9
(4,119 Views)
Dear sdzg'lkmarekngroe,
The previous responses to your question all sound good.
In the event that your control is enabled, included in the connector pane, and �change to indicator� appears in the menu when you right click on the control, try removing the control and recreating it. Sometimes controls or indicators can be corrupted.
Let me know if there is anything else that I can do to help.
Scott Romine
Scott Romine
Course Development Engineer
Message 7 of 9
(4,119 Views)
Thank you. I will try it.
Message 8 of 9
(4,119 Views)
Hello All,
I agree with Scott ROMINE. I just want to add one other potential solution:
In the event that you use a "Node Property" with your string control (Right click on the control>>create>>Node Property), be sure that the variable "disabled" equalize to zero.
Sanaa TAZI
Application Engineer
Message 9 of 9
(4,119 Views)
