not enough memory to complete operation
I've implemented alot of the recommended changes, ensuring that all arrays in my program are initialized and then using replace array subset (i had forgotten this on a couple of them).  I have also added some script to decimate the graph data based on the x-axis range so that I only wire 1094 data points, per plot, to the graphs.  I think wiring 4 plots of 100,000 data points to each could have cause some unforseen problems.
The code has been running now for 3 weeks without major incident.  There was a single case where the data files were being updated but not the front panel (viewed through a URL).  I think the laptop had implemented some power saving options and stopped updating the graphics (adjusted power settings and haven't seen this happen again)
Message 11 of 11
(915 Views)
