not enough memory to complete this operation
hi everybody i've seen a lot of posts under this heading but could not be able to find out regarding my problem when i am trying to open host vi from a project explorer window , after loading about 8500 dependencies (sorry if use wrong word), its starts giving error "not enough memory to complete this operation" plz tell me what type of memory is this message telling about? regards aqib
(3,576 Views)
How many VIs are in your entire project? Did this problem just start? Are you upgrading to a new version of LV? Can you open smaller pieces of the entire application?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,554 Views)
Can you post your code for us to look at? It seems that you may be opening things but not closing them and freeing up that memory. It could be a memory leak. It could be that a reference is being opened over and over again. It is hard to tell you what memory problem you are having wihtout code.
Tim
GHSP
(3,550 Views)
i am trying to open DQPSK modulator and demodulator given as the examples in RF fixed point library
(3,528 Views)
Hi islamabad,
In addition to the questions above, could you provide some information about your system, such as model of computer, performance specs, and version of LabVIEW and associated RF drivers? Thanks.
Joe S.
(3,497 Views)
