not executed
I made a PID controller and added a sub vi of a fuzzy controller. The idea is to add the outputs of fuzzy and PID controller. But when I run the vi it does not execute. Her is the vi attached . can some one help.
Message 1 of 11
(7,216 Views)
Hi Pargat,
which error do you get, when your VI is "not executed"?
Or does it run, but cannot iterate? (Which is quite a difference to "not executing"…)
Did you try to debug?
Message 2 of 11
(7,209 Views)
What exactly does that mean???
We are missing a subVI (fuzzycont.vi), so we cannot test your code. Make sure to attach all (or simplify so it runs without it while still showing the problem).
Message 3 of 11
(7,182 Views)
here is the sub vi .
Message 4 of 11
(7,142 Views)
The .fs file is not uploading
Message 5 of 11
(7,141 Views)
Hi Pargat,
"THINK DATAFLOW!" is all you need to obey!
Your subVI will run until you press that stop button. Your main VI will only iterate when the subVI has been finished - basic DATAFLOW!
Message 6 of 11
(7,122 Views)
Thanks for the reply first. Well my main vi is working and sub is not and when i press stop button there is no change. The output of the main vi reaches its upper limit but sub vi is not executed. How can they work simulataneously. Kindly help.
Message 7 of 11
(7,103 Views)
Accepted by topic author Pargat
Hi Pargat,
I don't believe  your main VI "is working" while the subVI is blocking DATAFLOW…
When you want to run things in parallel you need to program them running parallel - THINK DATAFLOW!
As long as you use this subVI in your mainVI loop the subVI will block the mainVI…
Message 8 of 11
(7,090 Views)
Dear Pargat,
What GerdW means here is that in LabVIEW (and I imagine any other programming environment you'd care to name) a loop can't go to the next iteration until after it finishes with the current iteration.
When you place a loop in your Main VI, which calls a SubVI who also contains a loop, the Main VI will call the SubVI once per loop iteration - every time the loop runs, it starts the SubVI. It can't go to the next iteration until the SubVI finishes!
When your SubVI contains a loop, it's often indicative that you want the thing in the SubVI to run over and over again - but remember that the SubVI is being called over and over again! If the SubVI contains its own loop, it has to keep running until its own loop finishes, before it can say to the Main VI - "Hey, I'm done, you can go to the next iteration now".
In many cases, the SubVI should be written to just run the code once - it will run the code again in the next iteration of the Main VI's loop. This is often the intended use for mistakenly looping subVIs - really, they shouldn't be looping, because the Main VI is doing that.
Message 9 of 11
(7,079 Views)
Thank you so much for sharing your view and helping me solve the problem.
Message 10 of 11
(7,072 Views)
