(not really a) diagram disable structure question
Just a tip: The diagram disable structure is a great "scratch pad" you can use on your block diagram where you put unrunable code that you don't want to delete. Is there something else you guys have used in the past? I use a lot of property nodes on my current project, and I like the idea of having copies of every one right there where I can drag a copy over to my block diagram without getting the broken arrow. Smiley Happy
PaulG.
Retired
Message 1 of 1
(2,351 Views)
