not using DAQ assistant in system
I want to ask a question if DAQ assistant is needed in a system for reading the input.
(2,507 Views)
Depends - From where you are reading the input and what hardware you are using for that .
You will need DAQ if you are using one of the DAQ cards from NI for measurement.
Regarding DAQ assistant , it helps  to configure the DAQ device.Using DAQmx you can get flexibility to program DAQ devices
(2,503 Views)
Okay,thanks alot 🙂
(2,500 Views)
