notification to alert that the student didnt return the equipment
Hello everyone
I am working on my project where i am stuck in one place. Actually i am monitoring equipment in and out of a room.
I am able to put the date and time the equipment is borrowed .
i put a fixed date of 7 days for the returned date.
but now i am having a problem..
i want to make a notification appear when the student didnt returned the equipment on time
how to do that.
Hope to hear from  somebody soon
Message 1 of 17
(3,699 Views)
Something like the 1 Button Dialog?
Message 2 of 17
(3,698 Views)
i didnt get you sir
Message 3 of 17
(3,693 Views)
which kind of alert do you want to have ? A pop-up, receiving a mail, the name of the student in red...
if you want to have a pop-up, you can use a 1 Button dialog window, that you can find in the Dialog palette (see the attached picture)
palette
Giuliano Franchetto
Student at the l'Ecole Nationale Supérieure des Mines de Saint-Etienne, cycle ISMIN (FRANCE)
Message 4 of 17
(3,682 Views)
What type of notification?  When do they get this notification?  What part of this are your stuck with?
Message 5 of 17
(3,681 Views)
i will share with you my VI and the excel i am storing the information.
The barcode and the QR code that i mention up is the barcode is the Tp which each specific student has. and the qr code is the information
found on the equipment
You will see the date of return= ( this i give a delay of 7 days)..
My problem ( if the student does noe return within that 7 days then there should be a notification that this particular student
didnt return the equipment and status should be put alerted).
i hope i am clear sir
Message 6 of 17
(3,671 Views)
what are you adding to... day of the week or year? how are you going to handle your addition when it is day 7 of the week or day 366 of the year(quotient and remainder)? have you looked in the comparison pallete for your needs when the current day is on/over 7 days old(greater or equal)? are you considering time, maybe adding 7 days worth of seconds to the elapsed 1904 date would be easier?
Message 7 of 17
(3,637 Views)
convert the time stamp...
Message 8 of 17
(3,610 Views)
hello sir
thank you for your help
yes sir it is year. because in the vi, the connect the day of the month and year also. i just put a PLUS 7 their, see my Vi sir.
But the day of the year when the student will come to borrow will be different for each.
i was trying with the days only.
sir the two example you send me, i dont know how to implement that in my VI
Message 9 of 17
(3,598 Views)
Instead of the big cluster mess, just take your timestamp and add the number of seconds in 7 days (which apok already showed you).  That will give you the due date (and time).
Message 10 of 17
(3,584 Views)
