now when we use the CWUI.ocx in VB,the control will tuen black about five minutes later?
Dear sir:
we're your customer .In 1999,we had bought LABVIEW 5.0 (serial number is G11x20586) from
Shanghai branch.
now when we use the CWUI.ocx in VB,we have told "this program contains componentworks evaluation-only
control which will stop functioning after 5 minutes of execution time. to order a development version of componentworks
contact your local national instruments",we can't find any way to solve this program .and your shanghai branch technical
support also can't give us some advices for it .so i want to get some information from you.
I hope to recieve some information ASAP.
Best regards!
(2,609 Views)
As long as i know, ComponentWorks is not included in LabVIEW, so that's the problem, if you don't own ComponentWorks you can only use this controls for five minutes. BTW if you own ComponentWorks, the problem should be reported directly to NI (I think), using options in www.ni.com/ask
Hope this helps
(2,609 Views)
