nubmer to Boolean
Hi all : I want to change number i32 to Boolean value ,, is there an object to do that  Thanks\
Message 1 of 11
(5,215 Views)
You can convert a number to a binary array in the numeric toolbox -> Conversion -> number to binary array function
Is this what you mean?
_____________________________
- Cheers, Ed
Message 2 of 11
(5,211 Views)
Are you converting a number greater than 1? If so, yes, it is called Number to Boolean Array.
You can find it in the Boolean or Numeric palettes.
R
Message Edited by JoeLabView on 09-02-2008 08:51 AM
Message 3 of 11
(5,208 Views)
I know this object this convert number to array ,, don't want to convert to array because I have one number only
Message 4 of 11
(5,202 Views)
One number can have, regarding of it's "resolution" many different states where the boolean can only have two. So the easiest way to do a conversion like you want one is to compare the number with a certain value (better use > or <, not = )....
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 5 of 11
(5,198 Views)
As you may be able to tell, we have not understood your request.
Please illustrate what you would like so we can help further.
Wild guess:
Have you tried using the bit-wise operations available by using the boolean functions like "And" with a bit mask?
Ben
Message 6 of 11
(5,192 Views)
Probably a simple ">0" from the comparison palette will do what you want?
Message 7 of 11
(5,191 Views)
JLV, You can use number less than 1 as well. Twos complement is used 🙂
- Cheers, Ed
Message 8 of 11
(5,188 Views)
I guess Elyan wants to convert a number into a binary string 😉
So, as explained at least one thousand times in this forum :
- if this is just for display : just change the display format
     1/ select the indicator type (U8, U16,...I32...  integers only) : right click >> representation.
     2/ ask for "binary" format : right click >> Format and Precision >> Binary
- for other purposes, search the forums !!!!!! For instance here, or here...
Message Edité par chilly charly le 09-02-2008 04:53 PM
Chilly Charly    (aka CC)
Message 9 of 11
(5,149 Views)
I realize that, but I didn't understand (still don't) why the question was being asked.  I figured, if the person want to convert numbers 0 or 1 to a boolean, then I would have suggested something different.  Converting a "number" to boolean has to give you an array to represent each bit that defines that number..
As CC mentionned, similar questions were asked 1000 times...  with just about as many variations on what is actually needed 😉
"Converting a number to boolean" is too vague a question..  SO our answers are just as vague.. LOL! 😄
Message 10 of 11
(5,142 Views)
