number addition onto itself
I'm a new LV7.1 user. I've been able to use it to control some stepper motors successfully for a while. I wanted to count how many steps I've taken but could figure out the algorithm to write it in LV. For instance,
in C++, if you want to increment a number:
n = 12    'number of steps to be added or subtracted depending on which button push
i = 100    'initial number
i = i+n    ' if the "up" button is push
i = i-n     ' if the "down button is push
How do I get this into LV format?
Thank you for any inputs,
Q
(2,543 Views)
qle;
Check the attached VI. Certainly you can do it more nicely with event structures. This is only to show you the concept.
Regards;
Enrique
www.vartortech.com
(2,540 Views)
Wow!!
Thank you, this is exactly what I need!! Thank you!!!
(2,517 Views)
