number of samples issue
when the software reads or streams data (and producing results on the graphs). i want to change number of samples whilst its reading data, and when the number of samples is changed the graph updates, without stop and starting the read again (which is what it does atm)
Message 1 of 24
(3,584 Views)
not letting me post the zip file
Message 2 of 24
(3,582 Views)
ZIPs are rejected if there is suspicious code (e.g. executables) in it.
Are you talking about DAQmx devices as source of data?
Norbert
Norbert
Expert: Geometry
Message 3 of 24
(3,550 Views)
I'm talking about Analog evaluation software for a board
Message 4 of 24
(3,542 Views)
This does not answer my question.
What analog evaluation software for a board are you talking? What is the hardware? What software are you using?
Norbert
Norbert
Expert: Geometry
Message 5 of 24
(3,535 Views)
im using analog 8_10 lead pulSAR evaluation software on a 7688 board. i was trying to zip the software (lv code)
Message 6 of 24
(3,518 Views)
I am not aware of this hardware and its software examples/APIs. Did you already contact the vendor for support?
Norbert
Norbert
Expert: Geometry
Message 7 of 24
(3,515 Views)
yh they can supply code, which is the zip file, but cant support changes  (what i asked at the top here)
Message 8 of 24
(3,511 Views)
Well, i am sure that no one on this forum can tell you if the driver for your hardware supports changes on the fly (read: dynamic during runtime).
DAQmx does provide that feature, but DAQmx is the NI driver framework for NI hardware.
So it is the vendor of YOUR hardware who has to tell you if it is possible to change things on the fly or if they have to be configured before starting interaction with the hardware.
If they cannot or will not provide that information, i recommend you to remove that hardware from your system(s) and switch to a vendor who provides more support/features.
Norbert
Norbert
Expert: Geometry
Message 9 of 24
(3,506 Views)
no issues with drivers,hardware etc. i was just asking about one change to the software (lv code),that should be made to it.
Message 10 of 24
(3,494 Views)
