number to fraction string +format value
Hi there,
I just met a stupid question which made me crazy, please help.
The question is simple:
Target: Numeric floating control-> number to fraction string -> format value -> desirable string format
For example: 20.00 -> 20.00000 (Q1: why extra 0s?)-> "20.00"
I use the following program:
why doesn't it work, please?
Thanks!
Message 1 of 8
(5,646 Views)
Hi TriStones,
"Why it doesn't work?"
Because you haven't read the context help for "Number to fractional string"! Especially the sentences on those two additional inputs of that function (Q1)...
I would suggest using FormatIntoString like that:
(I tried to replicate your example, but your wiring is very bad: it's not clear which wire is connected to which input...)
Message 2 of 8
(5,633 Views)
Hi GerdW
Thanks!
“Because you haven't read the context help for "Number to fractional string"! Especially the sentences on those two additional inputs of that function (Q1)...”
May I ask which sentences....?
"your wiring is very bad"
Actually this is one of the best I have, I just find no way to improve, could you give me some suggestion???
Message 3 of 8
(5,614 Views)
Use code cleanup tool. Or click on individual wires and do a Ctrl-B.  The problem was the wires you have going into the concatenate string function, particularly the space constant and the "Goto" constant.  The wires didn't line up with inputst to the function, so it was harder to tell than it should have been what the order of the strings were you were concatenating.
Message 4 of 8
(5,611 Views)
Hi TriStones,
"May I ask which sentences....?"
Those sentences:
The point on bad wiring has already been explained by Raven...
Message 5 of 8
(5,566 Views)
I want to display the number like this : 5.000 has to display 0005.0. Some one give the solution in Labview 8.5.
Anilkumar
Message 6 of 8
(5,426 Views)
Hi Anil,
try this:
Message 7 of 8
(5,422 Views)
Thanks GerdW It works Fine.
Anil
Message 8 of 8
(5,404 Views)
