numeric drop down menu
Dear Gurus,
I am clearly being simple and missing something here, despite a trawl of the help pages.
I have a 1 D array of numeric values. I want to create and update a drop down menu so a user can select a numeric value, a bit like a combo box, but with numeric data in there. No labels, just numbers. The array has a variable length.
Is there any way to do this without converting the numbers to strings and shoving it into a combo box? I've been struggling and failing with the Menu Ring
Paul
Message Edited by Manc Pablo on 08-12-2008 10:02 AM
"When I read about the horrors of drinking, I gave up reading"
(5,718 Views)
What's the problem with this method? It only requires a single function (decimal number to string) which can handle the entire array.
The same will work for a ring (which I usually prefer to combo boxes).
___________________
Try to take over the world!
(5,711 Views)
You're confusing the value of the ring with the string being displayed. The string is what the user sees in the dropdown. The value is what gets returned to the program. Thus, you need to convert the array of numbers to a string so you can set the strings that are displayed to the user. All rings work this way.
Note: You can wire the array of numerics to the "Values[]" property node. This will generate a list of items with "<>" characters around your numbers. Normally this indicates a value that has no corresponding display string. The "Values[]" property node is also considered a private property, not generally intended for normal use.
(5,707 Views)
Thanks guys, looks like I need to convert the numeric data to strings!
as for the value[ ] property node, I cannot see that when I right click..create..property node etc, only strings[ ] and strings and values[ ]
P
(5,705 Views)
That's because it's super secret private stuff and you need to add a couple of keys to the LabVIEW.ini file for them to appear. Stick with the regular "Strings[]" property. I don't think you want to make life harder for yourself by testing uncharted waters, especially if you're just starting out. Smiley Wink
(5,700 Views)
oh no, I've been using Labview since 1995, but up until now all I've every needed to do was to read/write to serial ports, set and read voltages using pre-written drivers and then some funky maths and a save.
until now........Smiley Very Happy
(5,697 Views)
