numeric in table
I just had a look at the vi - I've never noticed that behaviour before. So to avoid this, you have to add the "Key repeat?" event. Then it works as you want it to.
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 11 of 13
(861 Views)
hello,
i forgto.
i've changed to allow only numbers.
but if i pressed a charachter for a long time LV should be work wrong because the characters willbe filled in the table.
markus
Message 12 of 13
(861 Views)
Obviously it is not "wrong" - just unexpected.
After keeping a button pressed a certain time it gets repreated. So as mentioned before, using the "Key repeat?" filter-event can help you to avoid this. Just edit the event case so that the key-down and the key-repeat events are handled in the same case.
Using LV8.0
Message 13 of 13
(859 Views)
