numeric & time linking
It's possible to link a numeric with the Time?
For example: at time "X" I can see in the waveform graph
a number "i",at time "Y" I can see other number, f.ex. "j".
In conclusion: I'd see all number at the time that occurs.
The numeric and Time are joined by a cluster, but I can' create as a indicator a waveform graph.
(2,856 Views)
1) the cluster should be composed of an X array (not value) and an Y array, in that order. In your case, an array with time and another with numeric values.
2) create a brand new XY graph, then wire the cluster to it
Check the attached example.
Paolo
Message Edited by pincpanter on 06-09-2006 03:10 PM
Paolo
LV 7.1, 2011, 2017, 2019, 2021
(2,850 Views)
thanks, I will prove it.
(2,845 Views)
