numerical evaluation of a string
does anyone know how to do this?
for example, i have this string:
3*A+5-6*B
i want to plug in values for A and B (which i know how to do). then have the expression evaluated and give me a result. the operation is much more complex than this, and has to iterated about 600 times, so it becomes very complicated to do this with simple math.
Harley
(2,671 Views)
Harley,
It's hard to tell which LabVIEW functions you're familiar with and which you aren't, so apologies if I suggest something you're already aware of. I think more detail on exactly what you're trying to do might help.
One thought is to check out the Analyze >> Mathematics >> Formula palette and make sure you are aware of all the options there. If your main problem is the evaluation of a complicated multi-variable expression, then a good solution is Eval Multi-Variable Scalar.vi (on the Advanced subpalette of the Formula palette).
One thing that's not clear is why a more complicated mathematical expression, or the need to iterate many times, is a problem. Neither aspect really should make your effort much more difficult, assuming you've found the LabVIEW tools to accomplish the core task.
Hope that helps,
John
(2,667 Views)
HDS,
The formula node found on the structures palette allows you to do just as you are describing. Right-click on the border to add inputs or outputs. You can program using pseudo-C type functions. (see context help for more information on syntax) For iterations you have two choices: perform the iterations in the formula node using a loop...like in C....or place a loop around the formula node and use shift registers.
-cheers,
Brett
(2,644 Views)
