numerical integration of unevenly spaced data
Hello all,
Is there a VI (or does anybody have one) that can integrate unevenly spaced numerical data? I know the basic numerical integrator only works for evenly spaced data (data spaced at a constant interval)..
Thanks for youe help....
Jay Poret, Ph.D.
AOT, Inc.
(3,699 Views)
Help for the Numeric Integrator.vi shows the formulas. For the trapezoidal rule (the simplest one) the integral is the sum of partial sums which are given by: 1/2(x[i] + x[i + 1])*dt.
If you change dt to dt(i) = t[i+1] - t[i], I think this should give you a reasonable approximation. The more complex rules cannot use this approach. The trapezoidal rule simply sums the area under the trapezoids created by connecting the t[i], x[i], x[i+1], t[i+1] dots, so this change should not introduce any errors.
(3,699 Views)
John,
Thanks for the reply...I believe I solved the problem by creating a VI based on fitting my data with a cubic spline and then generating new y data based on evenly spaced x data. It actually works pretty well..
The trick is to use the two cubic spline Vis in the processing tools....
(3,699 Views)
Radman, could you go into more detail on what it is you are doing here? This is exactly what I want to do and I'm not sure what you are talking about by using two cubic spline VI's
(3,699 Views)
