nxt error
I am trying to program the nxt in labview 8.5. Basically, I am getting the following error below:
ERROR: An error occurred during parsing. Node was unable to be parsed. ((Class: DisableStructure)  (VI: Test_VI.vi:Instance:0))
ERROR: Indexing tunnels are not supported
I am trying to compare some data values from a chart with a constant value and then display a boolean output. My code is attached below. Any help is much appreciated.
(2,844 Views)
For better results, you might want to ask this in the NXT forum.
(2,835 Views)
