object oriented programming create control file
Hi everyone
I am starting to use object oriented programming in labview and I am confusing about some part.
1 ) In project explorer , Right click on My computer ----> New---->then there are VI, virtual folder , control and so on. What is exactly this "control"? when do I need to create new control.
I saw sample program and he put cluster on this control.
as briefly the work I want to do is to communicate with Fluk ( calibrator ) and PXI for automated testing.
(3,182 Views)
The control can be one of two things (or some combination of both...)
1. A control with a customized appearance
2. A "Type def." (similar to a C Struct) used to define a cluster that will be used throughout your program
When you create the control from the right-click menu that you mentioned, it should popup the front panel of the new control. The first thing you need to be made aware of is the left-most combobox on the toolbar. By default the combobox should have "Control" selected. Use this setting if you are simply trying to create a control with a different cosmetic appearance from the standard LabVIEW controls. These controls act exactly like any other LabVIEW control, you can place them on your front panel, change the shape appearance, data types, etc. without it modifying your control file. The other two options in that combobox are "Type Def." and "Strict Type Def.". By selecting type def, you are creating a control that when placed, is directly connected to the control file. Any changes made to the data type of the wire must be done through the control file. The only difference (that I'm aware of) between a type def and a strict type def is that a strict type def forces all uses of said type def to be cosmetically identical as well. When you modify a typedef file, all places in code that you have used that type def will be automatically updated with your changes (for better or for worse 😉 ). If you have an active license to LabVIEW, you should check out the free online Core 1 and Core 2 classes. They should cover control files in good detail.
Charles Chickering
Architecture is art with rules.
...and the rules are more like guidelines
(3,177 Views)
Thanks for your support,
I do have an active lisense , I will look forward online courses but as I am not familiar with object oriented programming and I started big project I might have more question, could I ask it in this post or I have to make new post ?
(3,163 Views)
